RE: AnyTrans for iOS
Dear Ckelley,
Thanks for using our app and i am truly sorry for the late reply. This is Dorothy and i hope to be able to help you!
It’s sorry for Home Screen Manager function can help you clean apps which are not downloaded successfully. And it can not help you delete app on your device directly. I am truly  sorry for the inconvenience has caused to you. It will be appreciated for your generous forgiveness.
Meanwhile, to delete apps, would you please give AnyTrans another function a try?
https://www.imobie.com/guide/anytrans/apps-management-ios.htm
apps management 5
Please kindly tell me whether it works for you or not.
Thank you so much for your generous support and kind feedback in advance.
Best regards,
Dorothy
Be the first to post a comment.
Add a comment
