RE: PhoneRescue for iOS
Hello Amy,
Thanks for uisng our app and i am truly sorry for the late reply. This is Dorothy and i hope to be able to help you!
If you reset to factory settings, your device data will be deleted permanently. And you are unable to recover lost data from iOS device anymore. But if you have iTunes or iCloud backup, you can recover lost data from backups.
Recover from iTunes Backup: https://www.imobie.com/guide/phonerescue-for-ios/recover-from-itunes-backups.htm
Recover from iCloud backup: https://www.imobie.com/guide/phonerescue-for-ios/recover-from-icloud.htm
Meanwhile, recovery process is a complex process. Thus, it is hard to guarantee that all data can be recovered. I highly recommend you to give the trial version a try before puchasing it. If the trial version fails to help you find important data back, please do not purchase the pro version. It will be appreciated for your generous forgiveness and kind understanding.
If there is anything i can help you with, please just let me know.
Thank you so much for your generous forgiveness and kind feedback in advance.
Best regards,
Dorothy
Be the first to post a comment.
Add a comment
