Jump to content
Welcome to iMobie Forum
jordan
How long for backup password recovery
Recommended Posts
I was wondering if anyone has any ideas about how long it takes for the password recovery of an encrypted iTunes back up to finish? I started 13 hours ago and the progress bar looks to be about 75% done, but has been at that same progress spot since I first checked it this morning about 3 1/2 hours ago. When I first started running the program, it made small progress to about 20% over a few hours so I don't know why the bars not moving anymore. The "Time Remaining:" has said >24 hours since I first started. I'm just trying to figure out if I should keep this up and how long it will take to be completed, or if I should try a different program.
Share this post
Link to post
Share on other sites
Hello Jordan,
Thanks for using our app and i am sorry for the dealy reply. To start with, i would like to explain that the time to decrypt password depends on the complexity of your password. The more simpler the possward is, the less time it takes. But if your password is complex (like combined with numbers + letters +symbols, etc..), it will take a long time to decrypt passward. In some rare situation,  it will really over 24 hours. It will be appreciated for your kind kind understanding.
Given the situation you encountered, to help me better analysis the time you need to take, would you please kindly send log file to Support@imobie.com directly for better analysis?
https://www.imobie.com/faq/anytrans-for-ios-faqs.htm#part44
Thanks fo your kind understanding and feedback in advance.
Best regards,
Dorothy
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
